Popping Noise
Hey guys - I have a 4" rough country with 35" tires. When I apply brakes I have a slight pop in the right rear - then when I gas from a red light I have the same pop. Only breaking and then gassing. I don't know if it is my springs or a control arm or what. Any suggestions?
I would go over all your suspension parts and make sure everything is tight. Also look and see if there is rub marks on your arms. check your track bar if it is adjustable I did't tighten the jam nut and it tore the threads out
