popping noise in front end?
Old Apr 18, 2010 | 10:32 AM
kking08's Avatar
Default popping noise in front end?
i recently added a teraflex 2.5 inch coil lift, still have stock wheels and tires. but ive noticed a popping noise at low speeds when making a turn? anybody have any ideas the jeep only has 1600 miles on it.
Old Apr 18, 2010 | 01:17 PM
mikegp's Avatar
Maybe whoever installed it placed something incorrectly. I would have it checked out my friend. I have the same lift and stock tires and wheels for 10000km and no popping sounds.
Old Apr 18, 2010 | 01:31 PM
wiredawg_mg's Avatar
Somethiing is loose. I would start with the front uppper shock bolts.
Old Apr 18, 2010 | 01:59 PM
JPop's Avatar
Are you feeling the pop in the steering wheel, such as a slight resistance while turning?
I'm leaning towards the axle U Joints as well, although I'd check out the steering box.
Old Apr 18, 2010 | 03:39 PM
kking08's Avatar
im not feeling it in the steering wheel, i took it back to the shop and they said it was the tie rod moving back and forth? not sure about that but it only happens when your turning at low speeds
Old Apr 18, 2010 | 04:14 PM
bone's Avatar
do you have sway bar disconnects? Mine pop at low speeds when I turn tight and the Jeep leans.
Old Apr 18, 2010 | 05:22 PM
kking08's Avatar
nope no discos
Old Apr 19, 2010 | 07:43 AM
andres47's Avatar
same problem
Old Apr 19, 2010 | 07:52 AM
TeraFlex's Avatar
Sponsoring Manufacturer
Re-torque the trackbar to 125 lbs. Check the top shock nuts. Do you hear the sound when you hit a dip/bump in the road?
Old Apr 20, 2010 | 11:03 AM
NonHyphenated American's Avatar
I had the same problem. I had my dad turn the wheel back and forth and saw that the passenger side spring was not seated right in the perches.
