Positive lead for winch is short
I installed a Q9500i on my 2013 JKU Sahara this weekend the postive lead won't reach the battery. I have ran it several ways and it still comes up 4-8" short. It would probably work if I ran it through the grill, not under it, and haphazardly across the engine compartment, but I would rather not risk damage to the cable or the consequense of a large amp short. I have sent a PM to Quadratec and was wondering if any others are having the same problem or found solutions.
I didn't want to make my own positive lead until I hear back from Quadratec regarding warranty issues if I do.
Thanks-
Thanks-
Thanks-
Thanks-
I would see what quadratec have to say.
If you dont hear from Quadratec check a custom car stereo shop. With all the high output amps and stuff they install they should have a good power cable set up for you.
The Chinese guy with the measuring tape F*cked up again? Someone needs to fire him...
Call QT get them to send you another one.
Buying 0 gauge copper wire is like buying gold by the gram its costly and you should not have to pay because they messed up.
I ran mine over the crossbar under the radiator under air-box and up to the terminals. There should be enough wire to do that. Also try to zip-tie them a clean looking engine bay is a respected one.
I would go this route, It's a good idea anyway. This way your winch has no power until you flip the switch inside the jeep. POWER INTERRUPT KIT; P/I KIT, RET
