Possible gear question?
Ok I have read numerous "regearing" threads and was wondering why my JK is so sluggish(kicking out of OD,BAD MPG etc.) . I replaced my factory wheels and tires (255-75R18) with 33x12.5R15, they both measure 32 1/4" tall. Is it because the width of the tire. I forgot to say my JK is a 2dr auto w/4.10. I shouldn't have to regear because I didn't actually change the revolution of my tires. What else can i do? It just seems that every one that has had to regear changed the diameter of their tires. I don't know what route to go gears, flashpack. This is my DD so i need to get it back close to what it was. Any and all responses will be helpful. Thanks
Although the diameter/revolution may be the same or close...The new tire may just be heavier than your original. 4.10 should be ok for that size tire. I definitely would regear (that's just me as I am always looking for more UMMPHHH in the JK
). But the other alternative would be to get the Superchips Flashpaq. I have one and have no regrets with it. That may give back some driveability to your JK...
Anyway, do you have any intention of going to a taller tire? If so, re-gearing is definitely the way to go. If you are staying with 33's, give the Flashpaq a try before you jump into gears.
I agree with ntinhuf, likely your 'actual' dimensions are different...could be a heavier tire....but you didn't say whether you changed from an AT fully inflated to a MT with lower inflation...that'll definately increase your rolling resistance, causing many of your symptoms
I did go from a AT to a MT both fully inflated. I measured them both off the rig and they both measured 32 1/4" tall. I wondered if the width didn't have something to with it. In the future I do plan on going bigger tire and bigger lift maybe I should just regear now. I plan on going 35's. I was just looking for a happy medium until then.
Here is some feedback from experience. I am running 33x13.5 LTBs which are heavy but the same approx diameter (my speedo is within 1 mph of GPS speed). Yes, the weight and rolling resistance makes a big difference, more than I expected as well. I can hold 60-65 on the freeway in O/D if I am lucky.
I have the flashpack and it makes it peppier around town, but doesn't help the highway that I have experienced. With the flashpack and O/D off, it works great but obviously the mileage goes down. I have 4:10's and plan to keep everything as is.
Thanks to all, I guess it is something that I am just going to have to live with it is a JEEP (wouldn't trade for anything tho) I will probibly check into a tranny cooler since I plan on taking road trips to Colo. and MO to do some real trail riding with it. There are none(trails) to really speak of in Iowa.
