Post TF 2.5BB install questions.
Hey guys, I JUST finished installing the budget boost on my 2door. I've never driven a lifted vehicle before (Or put a lift in), so I just want to ask all of you some questions.
I have just the 2.5BB from Teraflex with the shock extenstion adaptors.
First, sway bars. I was supposed to take the rear stockers and relocate them up front, right?
Rear sway bars: is there a certain way they should have been positioned??? (Grease fittings backward or forward.....Inside or outside of the calipers???)
I feel like the jeep is extremely wobbly. This may be expected, as the center of gravity is higher, but I'm not sure. I feel like it pitches and wobbles in any sudden movement. Any emergency maneuver may end up in a roll over, it feels
I just did this lift, and i'm not an expert but I definitely didn't move my rear sway bar links to the front. I just replaced the OEM front links with the ones provided in the kit. And for the grease fittings I made them face forward for easier access.
mine drives fine, it feels a little softer but I have the optional shocks, and there's a little more body roll but nothing major and I didn't even notice it after 2 days.
just my .2 cents
EDIT: WTF now I'm all confused... I just read the write up and I guess you are suppose to relocate the rear links to the front. whats the reason for this, and does it matter?
just my .2 cents
^^where did you order from im looking to get the 2.5BB with new shocks.
and yea on my last jeep i didnt move anything from the front to the rear when i lifted it, it just came with new hardware to use on existing parts that i wasnt replacing. and i had a 3in lift and it wasnt wobbly at all.
You are supposed to swap out the rear swaybar links. It's a quick fix if you did it wrong.
I'm just wondering if the position of mine is good.
I just noticed you need the rear swaybars inside (I mounted mine outside of the brackets). I do notice that the brake lines may rub on the shock too
I installed mine a few months ago (with new shocks). it definitely should not feel "extremely wobbly." from your brief description, it sounds like the front sway bar is disconnected; you might want to check it. mine feels pretty much like it did prior to the lift.
mine came with new front and rear sway bar links. you should have received at least new rear links (if so, you then need to put the factory rear links in the front and the new rear links in the rear). as already noted, the teraflex directions are terrible, so look up how to install the sway bar links in the "write ups" here. hope this helps.
