Potential Differential Cover Problems
Old Aug 7, 2010 | 06:00 AM
Crasher's Avatar
Default Potential Differential Cover Problems
I read that some after market diff covers can cause locker engagement problems in the Rubicon. If so, does the Riddler cover have issues. What is the solution? Another concern is the rear cover hitting the rear tracking bar. I have the JKS bar. If it hits, what is the solution? Do I heat and rebend the bar to clear the cover?
Thanks
Old Aug 7, 2010 | 06:22 AM
funwthmud's Avatar
on JKS's install sheet for certain track bars it simply says to use a hydraulic press to bend it. I would assume that is if you used heat and didnt cool it properly it could weaken it
Old Aug 7, 2010 | 06:30 AM
codysanders's Avatar
i have the same lift, with the jks front and rear and have no problems with my psc covers hitting. i belive poision spyders customs are the same as the ridders just a different stamp.
there was no metal removed from the diff covers to install mine on the rubi either.
