Power locks/windows
Old Jun 11, 2014 | 09:42 AM
rileybarber5's Avatar
Default Power locks/windows
I just bought a 2014 wrangler sport without power locks and windows. Is there anyway I can convert it to have power locks and windows? Has anyone done this before? If so, how?
I saw the kit online made to convert your jeep doors to power locks but they dont yet have it for a 2014.
Old Jun 12, 2014 | 06:11 AM
Cet99's Avatar
I did it on my JKU 11. Bought an aftermarket set for 4 doors and used the two masters for driver and passanger side and one for the tailgate. The two rear doors I bought the mopar factory ones as it's a PITA to try and fit the aftermarket ones on the rear doors. There are a few write ups on this including the mopar part #'s for the factory ones which you could use and then splice the connector to use on the aftermarket door lock controller and make em work.
Old Jun 12, 2014 | 11:46 AM
suicideking's Avatar
You can get it done with an alarm system too. I had a car about 15 years ago with manual locks. Bought the module with the car alarm and had the lock motors (servos?) installed. Wasn't very expensive. However, it would only lock and unlock when you turn the alarm off and on. I didn't have a button inside the car to lock/unlock. If you as a decent car audio shop, they should be able to give you an estimate.
Old Jan 14, 2015 | 10:33 AM
jar527's Avatar
Does anyone have a link to a write up on adding power door locks? I'm curious as to how to mount the actuators in the door. 1 install I've seen had them mounted so as the screws could be seen on the interior face of the door. Would prefer not to do it that way. Also how do you connect the actuator to the lock mechanism?
Thanks!
