Power Steering Cooler..
Old Apr 27, 2010 | 01:50 PM
rinkishJK's Avatar
Default Power Steering Cooler..
just curious, but has anyone installed a power steering cooler for a reg steering box setup on the JK??? it is a great idea.. my ram had a factory one and besides that having a rack and not a box (1500) the pump is similar. i thought it was very smart..
so has anyone done it or should i try it???
Old Apr 27, 2010 | 02:21 PM
frankie945's Avatar
Well, If I were autocrossing the JK I would add one.
Old Apr 27, 2010 | 02:24 PM
rinkishJK's Avatar
u think that would be the only situation it would aid??
i think that with all the steering wheel movement off roading or for any driving that it would help.
hell the factory caravans have one mounted to the frame... now there's an idea.. humm...
Old Apr 27, 2010 | 02:34 PM
POWER STEERING WORKS HARDEST WHEN THE VEHICLE ISN'T MOVING. a cooler would be a great idea.
Old Apr 27, 2010 | 03:18 PM
frankie945's Avatar
If your not moving then how do you think it's going to get air to cool.. It would be over kill IMO...
Old Apr 28, 2010 | 06:23 AM
rinkishJK's Avatar
moving or not bottom line is the fluid would have a spot to disapate heat.
Old Apr 28, 2010 | 06:46 AM
frankie945's Avatar
dot 3 brake fluid boils at over 400 degrees. I don't think it would matter much with a cooler or heat sink. I highly dought it will get that hot.
Old Apr 28, 2010 | 08:54 AM
rinkishJK's Avatar
the power steering runs on atf4, not brake fluid, and most trans damage is due to heat over 230. thats why ppl run aux. trans coolers.. to PREVENT damage.
i hope u didnt put dot 3 in your power steering...
Old Apr 28, 2010 | 08:59 AM
rinkishJK's Avatar
i've been looking online and i think i can get a complete cooler for under 50$..
now do i want to mount it to the cross bar at bottom of grill area, or use the zip ties to mount to condensor in front??
Old Apr 28, 2010 | 09:40 AM
frankie945's Avatar
oops, I haven't even checked the power steering yet.
