Power Steering Pump Upgrade
Are there any aftermarket bigger power steering pumps to replace the stock pump running 37 tires
Is any one running power steering pump cooler any pics would be great.
i looked at PSC but currently they are good for autos not manual...
I had an aftermarket steering fluid cooler on my CJ when I had the stock 258 and small power steering pump in it. I mounted it to the inside of my frame rail above the suspension. Got the cooler from summit, if I remember correctly. I've since moved up to a 351w with a Ford truck power steering pump in the jeep, so fluid boiling is no longer an issue. I have not run into any problems with the power steering on my JK. Are you having difficulties with the 37s or is this preventive maintenance?
I am currently running 35" and have noticed a little stiff power steering compared to stock and now I am moving to 37" i think my power steering will struggle.
So thats why I am looking for Power steering pump upgrade something bigger with fluid cooler infront of the radiator.
Did a lot of search but couldnt find anything
