power tank mounting options??
On another note with regard to CO2 refills I never realized that the larger liquor stores that refill kegs or home tap CO2 tanks can do the same with the PT for $1 per lb maybe less. I found a liquor store to be more convenient then locating a CO2 refill station. If you can weigh tank before and after to see how much fit otherwise you are likely to be charged for 10 lbs when only 7 fit. I use a small handheld battery operated digital fishing type of scale also sold by PT.
Enjoy!
what mounts are you using to mount to the roll bar? http://www.powertank.com/products/productID/75 Are they the TJ Roll cage mounts? WIll they work on the JK as well? Thanks
Brian
Brian
Now that's a nice set-up...Nice install
