Powertank Question
Old Feb 27, 2013 | 12:43 PM
  #31
bushpilot's Avatar
Originally Posted by conifers4
Wow! at $20 a tank that is a steal considering the link you provided shows them being $99!
agreed - they are often on sale for $50...and sometimes theyre priced wrong
Originally Posted by JKingAround
Don't waste your money if you want to run air tools most guns need 5 cfm min. I saw this on display at a show. And I could tell just by the sound of it. It won't do the job.
Exactly - but w/ a higher pressure & flow regulator it would be possible.
Old Feb 28, 2013 | 05:31 PM
  #32
TURTLECON's Avatar
Originally Posted by bushpilot
if anyone is interested in going this route -
i just ordered one from these guys - they have a minimum order so it can take some time, or you can pay 30 more for the same regulator and by-pass the minimum order amount....ill just wait.
this is the 2 stage (dual gauge) 5-175psi adjustable regulator, with gauge protector boots.
UNIWELD R1363 CO2 REGULATOR (5-175 PSIG) UPC 12311 NEW
order the above, add your own quick disconnect, hose and c02 bottle & youre good to go.
Would either of these work just as well as the Uniweld version? Basically you want one gauge for air pressure and one for tank pressure, right?
JEGS Performance Products 60200 CO2 Regulator with Dual Gauges : Amazon.com : Automotive
Amazon.com: Compact Co2 Regulator Dual Gauge: Kitchen & Dining
Old Mar 6, 2013 | 04:40 PM
  #33
TURTLECON's Avatar
Bump for an answer to my previous post
Old Mar 6, 2013 | 05:03 PM
  #34
TURTLECON's Avatar
got my regulator today - exchange my tanks (got empty ones at harbor freight for 20 bucks),
gonna had a handle/protector ($15 bux) and im into this for less than 100 bucks, even less if you consider i had the tanks sitting around collecting dust (the oldest one was free).
Is that the same regulator as the link you posted? The Uniweld site lists that regulator as a single stage single gauge.
Old Mar 7, 2013 | 10:34 AM
  #35
bushpilot's Avatar
yes ! despite what the uniweld site says, it IS in deed a TWO STAGE regulator
Old Mar 7, 2013 | 10:38 AM
  #36
bushpilot's Avatar
both COULD work...
the 2nd one has a pop off limit of 55-60 psi so as long as you never need more psi than that youll be ok....but
itll never be good for anything other than topping off tires (under 55psi).
Old Mar 7, 2013 | 01:43 PM
  #37
TURTLECON's Avatar
Thanks for the info. I really appreciate it! I ordered the Uniweld regulator you suggested... now I play the waiting game.
Old May 2, 2013 | 01:15 AM
  #38
bushpilot's Avatar
i just used my tank (again)...to top off/balance my 110psi coach tires....set the regulator to 175psi and it takes SECONDS to add a few pounds of air to a (previously) difficult tire to air up !
Old May 9, 2013 | 11:38 AM
  #39
conifers4's Avatar
Maybe I should start a new thread but my question is so simple.....Can a Powertank(or equivalent) be mounted horizontally or must it be vertical? Not for use but just during storage/mounting.
Old May 9, 2013 | 12:10 PM
  #40
renegade4x4's Avatar
You may mount the bottle anyway you like. To use co2 it should be in the upright position.
