Preferred adjustable sway links and why
Old Apr 14, 2015 | 02:42 AM
firecapt's Avatar
Default Preferred adjustable sway links and why
I am considering installing adjustable sway links on my 13 Rubicon. I installed a 1.5 Teraflex performance lift. With the weight of the new front bumper and winch I gained a little over an inch from original. The links with the kit have put my sway bars at about a 10 degree up angle. I believe the adjustables will allow me to adjust back closer to horizontal. What adjustable links do you guy prefer and why?
Old Apr 14, 2015 | 02:53 AM
jadmt's Avatar
JK-Forum Ambassador
JKS is what I'm using and well made.
Old Apr 14, 2015 | 06:37 AM
nthinuf's Avatar
10 degrees up on the swaybar is ok. It is short links/downward angle that you don't want.
I have had a set of JKS quicker discos on mine since 08, good solid choice. Only downside is you have to remove and store, rather than swing up and connect like the Teraflex style links.
Old Apr 14, 2015 | 06:48 AM
BigLow's Avatar
JK Forum Regional Rep
JKS from day 1. They grow with your jeep. I see more on JKS for non-rubi's than any other on the trail.
Old Apr 14, 2015 | 06:55 AM
The Black Jeep's Avatar
Currie anti rock then you don't mess with them at all and they grow with your jeep I have a Rubi but when my sway bar motor goes that is what I'm doing I had them on my tj and loved them tons of flex no disconnect and reconnect
Old Apr 14, 2015 | 07:31 AM
DunnyBunny's Avatar
JK-Forum Ambassador
I have RK. Really any of them work and pretty much do the same thing.
Old Apr 15, 2015 | 10:58 AM
firejeep508's Avatar
I put the JKS adjustable rear links on mine and the ends wore out in what I consider to be an unacceptably short period of time. I'm exploring new options now, leaning towards the Synergy links. I think they are probably way too long for your setup though.
