PRESS RELEASE - Off Road Evolution EVO 1015 Sector Shaft Brace
JK-Forum Founder
Don’t think this can happen to you? Think again! With the installation of a lift kit, big oversized tires and a dropped pitman arm, more side loading will be placed on the sector shaft of your steering box (which in factory configuration is a single shear mount) and more and more people that I know are starting to damage or break theirs. As a matter of fact, I have broken my sector shaft as well and when yours breaks - you’re walking!!
Fortunately for us, there is an answer to this problem and it is the all NEW bolt on EVO 1015 Sector Shaft Brace. Developed by our good friends over at Off Road Evolution, the EVO 1015 Sector Shaft Brace is a bolt on item that double shears the shaft and therefore helps to alleviate some of the side loading on it.
Features:
• Bolt on installation (Drilling of two holes required)
• Double shears the sector shaft inside of the JK steering box
• Helps to alleviate side loading on sector shaft.
• Can be used with any suspension kit that has a drop trackbar bracket on the frame side (i.e. like the kind that Full Traction, Rancho and Rubicon Express makes).
Needless to say, if you are running 35″ tires or taller and play hard on the trails, this really is a must have upgrade and I would highly recommend it. For more information about the EVO 1015 Sector Shaft Brace, please contact Off Road Evolution by email at: mel.wade@offroadevolution.com or by phone at: (714) 870-5515. Or, visit their website at: www.offroadevolution.com
bump stop?
sorry about the high-jack but..... whats up with that bump stop
( if it is one )? it look like a baby shock. or is it a part of the shock it self.
sick peace though. lokks rockhard .
Interesting, but I'm not too sure that will be effective. Side loads are typically not what breaks sector shafts. It is the feedback from the larger tires and wheels back through the steering components trying to turn the sector in the opposite direction of the steering wheel. In other words, "twist". Clearly, in that first picture, the sector has been broken with some twist. A side load break would be more cleanly broken. I've seen stuff like this home made for the older Chevy trucks that had the same problem, and it didn't help because side loading was not the culprit. I hope I am wrong on the JK, but it looks like the principle is the same.
Sponsoring Vendor
Double Shearing the shaft will help prevent breakage by supporting side forces and therefore the only inherent forces on the shaft (unsupported) will be twisting, which is what the shaft is made to support.
Sponsoring Vendor
We also have a factory location air bump stop kit.
http://www.offroadevolution.com/stor...od=EVO-AIRBUMP
Ok, cool. Thanks for the heads up. If you noticed, I did give myself a disclaimer in my last post. "I hope I am wrong on the JK, but it looks like the principle is the same." LOL
Sponsoring Vendor
