PRESS RELEASE: Rock Krawler DIY 2-Door Reverse Triangulated 4 Link Assembly
Rock Krawler Suspension is proud to release the DIY Reverse Triangulated 4 Link Assembly for Wrangler JK 2 Door Models.
For you JK 2 Door Owners looking to really think outside the box, this upgrade does it! Rock Krawler supplies a new cross member made from 3/16″ thick laser cut steel that mounts behind the transfer case. The new cross member has (2) new mounts with (3) hole positions for anti-squat adjustability. (2) supplied axle mounts made from 1/4″ thick laser cut steel also have (3) hole positions for further suspension tuneability. (2) 44″ long pieces of 1 3/4 O.D. .125″ wall DOM Steel tubing, (4) weld in bungs, (4) krawler joints and hardware are also included to complete the upgrade. We recommend having a heavy rear sway bar such as the Currie 1″ Anti Rock JK Rear Sway Bar for further tuning.
It is required that you have knowledge of fabrication and suspension setup prior to attempting to install this product! It is only for 2 Door Model JK’s!
The retail price on the upgrade is $599.
For further information please check out our website at www.rockkrawler.com or give us a shout at (518) 270-9822.
Respectfully,
