Preventing sagging?
Old Mar 4, 2010 | 07:34 AM
Steven4est's Avatar
okay so lets say im sagging about an inch as of right now with all my parts on there and instead of a 3 inch lift its a 2 inch lift now from sagging.....could i add a 3-4 inch lift and it compensate for the lost sagging without have to extend all that shit???
Old Mar 4, 2010 | 07:40 AM
Steven4est's Avatar
Originally Posted by ECHO
Lets start here..
2-Dr or 4-Dr
Auto or 6-Spd
Hardtop or Soft top
Current BB lift
What winch and bumper do you have?
2 door, 6 speed, soft top, 3.0 inch fabtech budget lift, rugged ridge xhd stubby with bull ring and smittybilt xrc 8 comp series with synthectic line and plan on adding the smittybilt xrc bumper with tire carrier...................thanks for helping me out man i appreciate this, ive been searching for days and want to maintain my lift while adding my mods but couldnt seem to find anything
Old Mar 4, 2010 | 07:51 AM
Steven4est's Avatar
This system utilizes the factory coil springs with 3" steel coil spacers. With the vast array of cab and motor combinations found in the JK, utilization of the factory coil springs with this system ensures that the vehicle will receive a full 3” of lift to clear 35” x 12.50 R17 tires. This system includes a replacement Pitman Arm, front and rear Trac Bar relocation brackets, Sway Bar mounts, front and rear Bump Stop mounts and more. Proper front-end alignment is insured with this system due to the included adjustable alignment cams. Also included is a front driveshaft boot clamp kit to allow additional clearance between the front driveshaft and transmission during full suspension articulation.
thats everything it has
Old Mar 4, 2010 | 07:58 AM
Steven4est's Avatar
oka ill call him, but you think if i just add the teraflex 3-4 inch springs ill be good?
Old Mar 4, 2010 | 08:04 AM
Steven4est's Avatar
thanks man i just talked to joe he said go with the 2.5 inch teraflex springs and it will give me 3.0 easily with my bumper and everything. thanks for the help!
Old Mar 4, 2010 | 08:17 AM
wazooz2424's Avatar
TF all the way.
Old Mar 4, 2010 | 08:20 AM
HG07JKRubi's Avatar
Originally Posted by ssunde1
well 4 door rubicon coils are stiffer than say base 2 door x coils.
And they will sag too. Upgrade to OME or Teraflex coils and you'll get your lift back.
Old Mar 4, 2010 | 08:34 AM
JK Rocker's Avatar
I had a TF 2.5 budget boost, added bumper and winch, and sagged a LOT. I talked to Joe, who recommended to remove the front spacers, and if I have a 2 door, use 2.5" springs, and 4 door, use 3" springs. Since I have a 4 door, I got the 3" springs, and I sit perfectly level now. I still just have the spacers and stock springs in the back.
If I were you, I'd get the 2.5" springs and then add a 1" spacer later if it isn't enough.
Old Mar 4, 2010 | 07:47 PM
captjay's Avatar
rubicon express springs are stiffer than an old man in a strip club on viagra getting a lap dance
if u need more support then go with the Bro
Old Mar 4, 2010 | 07:56 PM
Riptyd's Avatar
I went with JKS ACOS, now I have adjustability to my lift. If I add a bumper I adjust. If I add a Winch, I adjust. Different tires with a slightly larger Diameter, I adjust. Get new springs, fine tune my adjustments for spring rate. look into it.
