Pro-Cal
Old Feb 24, 2009 | 09:06 AM
HarryHood1's Avatar
Default Pro-Cal
JUst got the AEV procal yesterday and had a qhestions about it . There is 1 setting not sure about, it is the Throttle Tolerance programming mode. Not quite sure what this does.
Old Feb 24, 2009 | 09:32 AM
jkkat's Avatar
Call Northridge4x4 360-340-0282
Old Feb 24, 2009 | 09:47 AM
Northridge4x4's Avatar
Sponsoring Vendor
I am looking into this and will get you a answer asap.
David
Old Feb 24, 2009 | 10:08 AM
HarryHood1's Avatar
thanks Dave
Old Feb 24, 2009 | 10:25 AM
Littlejon's Avatar
This mode allows the user to program throttle tolerance and effectively pair a PCM and pedal. When a new PCM or pedal has been installed, the previous values stored in the PCM may not match the specific tolerance of the pedal and need to be reprogrammed.
Sounds like it is for a when you get a new engine, gas pedal, or PCM.
Old Feb 24, 2009 | 10:47 AM
armycop's Avatar
From what I have been reading this is for engine swaps to a hemi and throttle by wire compatability.
Old Feb 24, 2009 | 01:29 PM
Sponsoring Vendor
Here you go !
Throttle Tolerance programming mode is to "learn" the throttle when installing a new pedal or engine...like a V8. It's part of the hemi installation, otherwise a customer would need to tow it to a dealer for the initial startup procedure, same with the vin.
David
Old Feb 24, 2009 | 03:03 PM
RA070424's Avatar
Former Member
So if your Jeep has "learned" your driving style, could you reset its knowledge and drive differently?
Old Feb 24, 2009 | 03:14 PM
eDiveBuddy's Avatar
I believe it's so the computer knows where no throttle and max throttle are.
Old Feb 24, 2009 | 03:55 PM
HarryHood1's Avatar
thanks for the help guys
