Pro Comp 7033
Old Apr 12, 2011 | 08:47 PM
txdiamond17's Avatar
Default Pro Comp 7033
I am about to pull the trigger on some wheels. I really like the pro comp 7033's in the 17x9. They have 4.75 backspacing. Does anyone have any info on if they will rub with 35's? I don't know if the .25 will cause any rubbing issues. Thanks for the help
Old Apr 13, 2011 | 05:33 AM
CrazyShadow's Avatar
My pro comp 1069 are 17x9 with 4.75BS, I run 285/70/17 and I can tell you there is still 1.25'' clearance between tire and sway bar at full turn. So with 12.5 wide tire I think you will be fine
Old Apr 14, 2011 | 04:32 AM
Thanks for the info. I was hoping to hear that. Guess I'll give it a try.
Old Apr 14, 2011 | 05:01 AM
Rexlba's Avatar
I've got the same 1069's with 4.65 bs. I'm running 35x12.50 and have no problems with rubbing
Old Apr 14, 2011 | 05:21 AM
cajun01's Avatar
Tera flex 2.5 and 35s no problems
