PROBLEM : Installed 2.5 skyjacker lift.
Old Feb 3, 2007 | 10:56 AM
jeepercreeper's Avatar
Default PROBLEM : Installed 2.5 skyjacker lift.
Problem after installing 2.5 skyjacker lift. My rear axle is off centered by a half inch. On 4 door jk Rubicon. The wheel on passenger side measures 13 1/2'' from frame. Wheel on driver's side measures 14'' from frame. Can anyone please help? Where did I go wrong?:confused:
THANKS..
Old Feb 3, 2007 | 11:16 AM
HDFFR's Avatar
Sounds like a problem with the track bar. Did you install the relocation bracket?? , is it installed in the correct hole ( i think there are two holes in the bracket- not sure though. Other than that I don't have a clue what could have gone wrong. Chris
Old Feb 3, 2007 | 11:34 AM
Yes I installed the relocation bracket. Used bottom hole as instructed for track bar.
Old Feb 3, 2007 | 12:44 PM
duneslider's Avatar
I think the only way to get it perfectly centered is to use an adjustable trackbar.
I could be wrong though, but that is what I have heard.
Bryan
Old Feb 3, 2007 | 08:08 PM
Rubimon's Avatar
That is what the relcation bracket should do. It should be designed to recenter the axle or why bother using it.
