problem with teraflex leveling kit
'11 2dr rubi 400 miles. installed this kit today at my buddys garage on a lift. install went smooth, however after we brought it back to the ground to tighten everything up we noticed the passenger side coil bowed pretty bad it isnt rubbing the swaybar link but its real close 1/4 or less. my guess is the axle shifted a bit which would be normal the geometry changed with no adj trackbar. what i dont understand is why the passenger side coil is so bowed and the drivers side is straight. if the axle shifted that bad wouldnt both coils have a similiar look?
1st pic is the passenger side 2nd is driver side. thanks
1st pic is the passenger side 2nd is driver side. thanksYou can Private Message the teraflex rep to see if he sees something funny or has seen this before. He is a member of the forum and a lot of help.
thanks for replying. i cant say much for my wrenching skills, im just an electrician but my buddy who installed it is a 20 year mechanic who has his own shop. that doesnt mean he's infallible of course so just in case i triple checked and both coils are seated properly. same for the spacers and isolators at the top. i know he loosened everything, control arms, sway bar links etc and tightened on the ground. i cant remember if he loosened the track bar however. i know the stock trackbar isnt adjustable but do they have any play in them at all when loosened?
1st pic is the passenger side 2nd is driver side. thanksI retract my first response, looks to be seated correctly. You might want to check the top.
https://www.jk-forum.com/forums/show...t-installation
took a few more pics this morning once the sun came up. everything is 100% seated properly. swaybar link is REAL close on the drivers side maybe a 1/4". passenger side is more like 3/4" away. the only thing we didnt loosen during install was the trackbar. im not looking to assign blame i just want it right. any suggestions from experienced guys as to what my next step should be? is this normal and im just being anal? thanks
