problems with evap relocate??
Old Mar 3, 2010 | 08:14 AM
jason0341's Avatar
Originally Posted by ssunde1
who had had any problems after relocating. thinking of ditching the skid and relocating for the prospect of a off road exhaust in the future, just not sure if im up for it or if its worth it or if i should just let the skid do its job.
What skid you running Scott? If you want to sell it off let me know, i may be interested in one.
Old Mar 3, 2010 | 12:01 PM
sin52's Avatar
Originally Posted by robin
I know i used your write up to relocate, and everything went fine, but every once in a while I have a hard time filling up the tank I know is because one of the hoses tha goes to the evap is more bent than it should be
I don't think it's the bent hose that causes it. Mine are kinked and I've had zero problems(one is about 75% closed in 2 spots). The vent from the evap canister goes to the top of the fuel fill neck. there is a separate thinner line from the top of the fuel tank that goes to the filler neck too(skips right past the evap can). There is a known fueling overfill problem on some Jeeps(sure you've seen the threads). Some Jeeps are more susceptible than others, and a large majority who had fueling problems had them without an evap relocate.
Old Mar 3, 2010 | 01:52 PM
ssunde1's Avatar
yep, i stop mine right before its about full cause otherwise it will overflow 90% of the time and i havent relocated. yet
Old Mar 3, 2010 | 01:53 PM
ssunde1's Avatar
i already told a buddy of mine he could have it when i relocate. sorry brotha
Old Mar 3, 2010 | 01:56 PM
azrwilkinson's Avatar
I was told by a tech at the stealership that you could potentially fill the evap up with gas by topping off your tank all the time. He told me to stop once it clicks the first time. Dont know how true this is???.....
Old Mar 3, 2010 | 02:00 PM
ssunde1's Avatar
well in mine the pump doesnt click until gas is already pouring out
