Problems wiring winch
I installed by Smittybuilt XRC 9.5 Gen2 winch. I wanted a cutoff switch so I used this one:
Battery DoctorŽ Rotary Dial Disconnect Switches - Wirthco Engineering, Inc.
I purchased it from Amazon. I ran the neg from the winch to the switch, and a short cable from the switch to the battery. And the winch works regardless of the switch position. I emailed Wirthco and they give the same instructions. So is the winch otherwise grounded? Should I put the switch on the hot side? Thanks
