Problmes after lift
Old Feb 23, 2012 | 07:41 AM
baz0157's Avatar
Default Problmes after lift
Anyone have any advice on how to fix my rear springs? After having them installed..they have a bind on them...and the left spring is touching the rear track bar.
Old Feb 23, 2012 | 08:00 AM
Atch's Avatar
The left spring?? I've seen ppl with problems touching the right spring. Is the track bar in correctly? Is your spring seated 100%?
Old Feb 23, 2012 | 08:13 AM
Rock Krawler Suspension's Avatar
Former Vendor
We have inexpensive correction wedges that will correct the bottom spring seat for your coils!
Here is a link to them!
These should do the trick for you!
RK
Old Feb 23, 2012 | 08:16 AM
smittycm's Avatar
Veteran: Marine Corp
You could probably get away with coil spring wedges and some spring retainers. A few companies make them. I think most people would say the correct way to fix it would be to either cut off and reweld your spring perches in the correct position, or use adjustable spring perches.
Old Feb 23, 2012 | 11:09 AM
baz0157's Avatar
I apologize for the miss print... It is my right spring that is rubbing the track bar. I have correction wedges installed and the springs still don't look to be seated correctly...
ID:	281420   Click image for larger version
Old Feb 23, 2012 | 11:29 AM
SilverBolt's Avatar
Did you measure your pinion angle before and after? It looks way off.
Old Feb 23, 2012 | 11:38 AM
sneck's Avatar
that looks all sorts of wrong. lift details? It almost looks like you're running an aftermarket upper control arm that is too long?
Old Feb 23, 2012 | 11:52 AM
BKGM Jeepers's Avatar
I haven't seen that before. I am guessing that you've got your pinion angle set too high. If your angle is correct, then paying someone to cut off and relocate both lower coil brackets is probably the next option.
I've never seen a mid-coil interfere with the track bar like that...
Old Feb 23, 2012 | 11:55 AM
baz0157's Avatar
Im pretty sure it is all sorts of wrong! Just ordered new lower control arms and track bar. I do have adjustable upper control arm installed. This problem started after putting the new drive shaft on.
Old Feb 23, 2012 | 12:05 PM
sneck's Avatar
did you get the right length driveshaft? it almost sounds like the axle is just set back too far, and the pinion angle looks way way off
