Procal with manual?
Old Nov 10, 2013 | 01:25 AM
stevo1371's Avatar
Default Procal with manual?
Hey people- I've just lift my Jk and put on 35's
Is it worth the 150$ to change my computer if I have a manual? Obviously I won't need to change the shift points set point. The only plus I can see is having a true MPH. Thoughts?
Thanks
Old Nov 10, 2013 | 04:08 AM
BossHog's Avatar
Double post. See below.
Old Nov 10, 2013 | 04:11 AM
BossHog's Avatar
I would bite the bullet and do it. In addition to a correct speedo, it can correct your odometer (imperative for vehicle resale) and adjust the points at which your tpms sensors go off. It also has a host of other features that can be used down the road should the need arise.
Try to look for a used, unlocked one for a bit less.
Old Nov 10, 2013 | 04:14 AM
kh202's Avatar
IMO no. I can deal with speedo being off by 5, and deal with tpm light
Old Nov 10, 2013 | 05:02 AM
beermantsw's Avatar
I put on 35s on my JK with manual shift and the dealer showed me how much the speedo is off. its only off by 4 mph at 65 mph. So i didnt bother reseting mine
Old Nov 10, 2013 | 05:19 AM
karls's Avatar
The procal will change your speedo, odo, turn off the tmps light (if you didn't move the sensors), and allow you to get your steering wheel dead centered.
So is it worth it? That's up to you. But....for $50 more than the procal sometimes you can find a used superchips which adds code reading (wheel speed sensors) and tunes for the computer. So again- it's up to you and your driving habits.
Sent from my DROID4 using Tapatalk
Old Nov 10, 2013 | 06:56 AM
Matthewd5's Avatar
I got one because I went up a bunch in tire size and regeared
I got the AEV one
Matthew
Old Nov 10, 2013 | 09:01 AM
courtsm3's Avatar
Had the procal and now superchips flashpaq. Ive heard the procal is better at adjustments but im happy with my other options with the flashpaq.
