Procal programmer
Old Jun 27, 2013 | 05:11 PM
Gman*2007's Avatar
Originally Posted by Andy's unlimited
I'm interested in ordering a procal programmer for my 13 jk unlimited an woundering if it worth the money an dose it really make a difference on the shift point for the automatic with 3.21 gears an 33" duratracs I know it will correct the speedo but woundering bout the shift points thanks
Go for it. Welcome to the forum.
Old Jun 27, 2013 | 06:07 PM
jadmt's Avatar
JK-Forum Ambassador
I have a 2013 with 33's (285/75-16 toyo at 2's ) I used the procal to recalibrate my speedo (both speed and odometer are spot on). I have auto and 3.21's and I have what I consider perfect auto shifting. I have read on forums so many times how the 3.21's and 33" tires suck and are always hunting for the proper gears. I just returned from a 2500 mile trip to Moab and back and was fully loaded down and never had an issue and between here and there are many long hills and elevation gains etc. I drove at least the speed limit or just above (speed limit for the majority of the trip was 75mph and I drove between 75-80mph) and my tranny rarely hunted for gears. It stayed mostly in 5th gear except on the return when I thru Idaho and then into Montana I had a very strong headwind combined with Monita pass. It would shift down to 4th and sometimes to 3rd to maintain 75-80mph. I guess my point is I think it is important to have your speedo calibrated so you get proper shift points.
Old Jun 28, 2013 | 05:20 PM
Andy's unlimited's Avatar
How dose it work to center your steering wheel
Old Jun 28, 2013 | 05:56 PM
nthinuf's Avatar
It shows you where the computer thinks center is by turning on the turn signals. You will be kneeling in front of your jeep turning the turnbuckle on the drag link, and you will see turn signal showing you a direction. Keep turning until both lights are on.
Using just the steering wheel as a guide isn't as accurate.
Old Jun 30, 2013 | 03:20 PM
Ok guys I got my programmer in the mail yesterday reprogram my ecu for my 33" tires an man did it make a world of difference my speedo is accurate now shift points change went for a 150 mile run my gas mileage improved from 16 to 18 in the city and was running 70 to 75 on freeway an was averaging 21 to 22 depending on my right foot I would defiantly recommend this product even just if you are changing tires to bigger than stock
Old Jun 30, 2013 | 03:41 PM
pingman77's Avatar
Wow. My jeep doesnt even sniff 17 mpg. More like 15. Thats with procal recalibration, and never getting my rpm above 2000. I guess some just have better luck.
Old Jun 30, 2013 | 04:44 PM
jadmt's Avatar
JK-Forum Ambassador
I would be upset if I only got 15mpg while doing 70-75mph. I just returned from Moab and coming home driving 75-80mph in a stiff head wind I got over 16.5mpg. I get at least 15mpg even when wheeling. Maybe you need to get your rpms up above 2K. My jeep computer is all over the place for mpg and I hand figure every tank. Some times the computer shows less mpg then actual and sometimes more.
Old Jun 30, 2013 | 05:36 PM
pingman77's Avatar
I travel 370 mile round trip every week doing 73mph on interstate in central tx. For tge most part its flat, but a steep hills. Its constantly downshifting on these hills. Im hoping a regear from the stock 3.21 will help. Im just trying to decide 4.10 with current tires or 4.56 with 35's?
Old Jun 30, 2013 | 06:02 PM
jeeperjkjeeper's Avatar
a guy in my club has one for sale for $100.00 if interested pm me
Old Jul 1, 2013 | 06:38 AM
Yellowfin's Avatar
Lol.....if I'm running anything over about 65 mph, I'm in the 13-14 range. If I keep it at 60 mph or under, I can hit about 16.5...17 if I have a nice tail wind. But then with 37's and 5.13's, I didn't really expect to get Prius fuel mileage. Hence the reason my JK is no longer a daily driver.
