Procal programmer worth the $$?
Old Aug 9, 2010 | 05:00 AM
Widowmaker's Avatar
I am pleased with the procal also. It is very simple to use, just keep in mind it's a programer and not a tuner. But for the price and ease of use I give it a
Old Aug 9, 2010 | 05:13 AM
RedRock GatorRaider's Avatar
I previously owned the PROCAL and it's a great little tool.
However, for less than another $100, you can also get an Aeroforce Interceptor Gauge which does pretty much everything the Procal does, but also displays everything reported by your Jeep's computer.
I use mine primarily to monitor my Transmission Temperature, and have the visual alarm set so that I know when it's getting too hot.
Check out my previous writeup here:
https://www.jk-forum.com/forums/show...erceptor-Gauge
Old Aug 9, 2010 | 09:09 PM
fitzb's Avatar
Have it, Love it. Cheap and very easy to use. Programed everything in 10 min !!!
Old Aug 10, 2010 | 11:39 AM
EHarris's Avatar
JK-Forum Ambassador
I've used it to re-program my Spedo and TPMS. Has anyone had any luck with the Stability Feature fix with this product? I can't stand driving on ramps anymore. Even with the button off it still kicks in.
Old Aug 10, 2010 | 11:45 AM
nthinuf's Avatar
New feature? Haven't seen any info about it. Happen to have a link or anything?
The owners manual has a procedure to permanently disable the ESP. Might be worth a shot.
Old Aug 11, 2010 | 11:48 PM
EHarris's Avatar
JK-Forum Ambassador
That's it. Permanently disable. I'm gonna try it once more and if it doesnt work I'll post up. Thanks.
Old Aug 12, 2010 | 05:04 AM
Doc_D's Avatar
Why not just address the mecahnical issues instead? When everything is set up correctly, ESP works exactly like it does on a stock vehicle. When your caster, toe, axle alignment and steering wheel alignment are correct it's a non-issue.
Old Aug 12, 2010 | 01:31 PM
EHarris's Avatar
JK-Forum Ambassador
Interesting....I wonder if Im not centered now that you mention it. I figured for sure with front and rear track bars I would be.
Old Aug 12, 2010 | 04:47 PM
jantonix's Avatar
I bought it for my 35s to fix my speedo therefore also fix on odo, i turned the daytime running lamps to fogs only which is great, also the high idle function, great product by aev for its price.
