ProCal Question
Old Oct 19, 2009 | 07:57 PM
vtwin17's Avatar
Default ProCal Question
When flashing for the tire size do I measure the tire on the JK with weight on them or off such as using the spare for measuring? I'm running Toyo open country AT 285/17x16 on Black Rock 997's. Thanks
Old Oct 19, 2009 | 08:00 PM
wildandwillin's Avatar
just measure the tire If you want percise measurement chalk a line on tire and ground roll till you are back on the tire line measure and devide by Pi. Or just measure the tire where its at. Ither way youll get the same within a 1/4"
Old Oct 19, 2009 | 08:09 PM
nthinuf's Avatar
You could look at the instructions...
In order to program the proper tire size, a measurement of the front tire will need to be taken on the vehicle under normal load and air pressure rounded to the nearest quarter inch (1/4”). Do not use the manufacturers listed tire size.
Old Oct 19, 2009 | 08:40 PM
spinlock's Avatar
Measure the tire height on the Jeep (with load). The diameter can be 1-1.5" less for a 33-35" tire when loaded. The Procal can be calibrated to within a 1/4".
Old Oct 20, 2009 | 03:45 AM
pearl-drum-man's Avatar
By following the directions mine seems to be spot on.
