Procal settings
Old Dec 27, 2012 | 08:48 AM
jh78tbk0livery's Avatar
Default Procal settings
Every dog has his moment, and I guess this is my turn.
I just got my special order 2013 JK 4 door (still have paper tags). UPS,FEDEX, and USPS are delivering all today, my Rock Hard full width bumper, and 33 inch K2'S with TKO 15 inch rims. Rough Country 2.5 spring lift, and 3/4 inch spacers for extra weight on the front are here.
My Quadratrac intigrated 11500 winch is also here
So, it is time to lash all this together!
My question on the Procal, which I just opened up. It says I can disable the TIPM sensors. Does that mean I can mount normal valve stems in these tires?
Truely turned off, or if I leave the tire monitors off, I may get some kind of "missing" display?
Old Dec 27, 2012 | 08:54 AM
jeep-rat's Avatar
on my 2013 when you start it up you get a display showing all for corners as 0 psi. This is with the TPMS set to disabled and using the current 2013 ready Procal. I am using regular rubber valve stems. You can dismiss the display, but it shows every time you start it up
Old Dec 27, 2012 | 08:59 AM
I just tore open the procal box a few moments ago. It said 2013 compatible on the cover, so , sounds good. But, does the darn EVIC go straight to that, or stay on what I have it set on (compass/temp) ?
Because it it goes directly to the zero settings each time I crank that dude, I will go ahead and put the sensors in and just set em low, to leave me alone
Hey, thanks for the quick reply. Let me know.
Wayne
Old Dec 27, 2012 | 09:04 AM
jeep-rat's Avatar
it goes straight to showing 0 each time you turn it on. I just hit the button and change to compass
Old Dec 27, 2012 | 09:16 AM
Gotcha,
Thanks for the heads up.
Will it do the same if I set it to a setting to truely worry about, like 20-24 lbs?
