Procal Shift Points
Old Feb 21, 2013 | 12:04 PM
Logan1982's Avatar
Default Procal Shift Points
Hey guys, I have a quick question and hopefully you can give some input. I set my tire size on the AEV procal to 31.75 for Falken Rocky Mountain 285/70/17's which on the website show 32.8". I measured the size loaded and at 28psi. I noticed now at 40-45 mph my rpms sit at 2000rpm then once a little over 45mph shift back down into the low 1000's. It almost seems that it's reving for a while before it shifts. Anyone else have this issue or run into something similar?? Any advice would be greatly appreciated.
Old Feb 21, 2013 | 12:52 PM
suicideking's Avatar
When I measured mine, I used a level and measured from the most level point to the ground. Seems to work great.
I'd try re-measuring. Disregard what the manufacturer says. You need to measure actual size.
Old Feb 21, 2013 | 01:05 PM
Logan1982's Avatar
Thanks suicideking!
Old Feb 21, 2013 | 01:10 PM
jadmt's Avatar
JK-Forum Ambassador
Another easy way to measure is park on a flat cement surface ie garage floor and measure from the floor to the center of your hub and X2.
