ProComp driveshafts???
Old Mar 4, 2011 | 08:57 PM
20JK10's Avatar
Default ProComp driveshafts???
I was browsing the 4wd.com website when I saw that they now have ProComp front and rear driveshafts available for JK's with 0-4" lift. And from looking at the pictures, it seems they are not a double cardan style like other shafts are.
This is from their website: The factory driveshaft ball and cage design joint is replaced with #1310 style u-joints to allow for a stronger engagement, increase the range of motion, and improve seal and driveline life. Exclusive yokes, not flange adapters, are used to allow for a longer driveshaft, unlike our competitors versions. Pro Comp Suspension rear driveshaft’s are constructed from 3.00”x 0.095” DOM (drawn-over-mandrel) steel. Kits come complete with necessary mounting hardware.
Now I know ProComp isn't the most popular brand out their, but would there be any benefit with going with their single cardan style shaft over a double cardan shaft?
Old Mar 4, 2011 | 09:02 PM
BKGM Jeepers's Avatar
It's fine if you don't plan to run a lift of any significance.
Basically any lift of 3" or more would require a cv shaft. Just be sure you don't want to go up.
Old Mar 5, 2011 | 03:20 PM
20JK10's Avatar
So they would be fine with a 2.5" lift?
Old Mar 5, 2011 | 03:22 PM
nthinuf's Avatar
Call Woods or Coast or Reel and have them build you a single cardan ds if that is what you want.
Old Mar 7, 2011 | 07:24 PM
20JK10's Avatar
I'm just wondering what makes a double cardan more beneficial then a single cardan? Every time I read a post about someone blowing apart a transfer case, they have a double cardan driveshaft.
Old Mar 20, 2011 | 12:19 PM
20JK10's Avatar
Anyone have a ProComp driveshaft?
Old Mar 20, 2011 | 03:17 PM
renpia's Avatar
I don't think I would buy a Procomp DS when there are other more reputable drive shaft manufacturer's out there like Tom Woods or Coast.
