procomp rims?
Old Aug 10, 2009 | 05:12 AM
mikesjk's Avatar
Default procomp rims?
Do you guys recommend pro comp lug nuts or use the factory ones. I am getting ready to order pro comp steal rims.
Old Aug 10, 2009 | 07:06 AM
JeepDawg's Avatar
Not the factory ones.....I went with Gorilla but obviously the Pro Comps will work.
Old Aug 10, 2009 | 08:09 AM
NewfieScreech's Avatar
I put these on my pro comps...
http://w ww.jegs.com/i/McGard/671/65330/10002/-1
They're a great looking locking nut!!!
Old Aug 10, 2009 | 08:55 AM
Piginajeep's Avatar
be careful
the xtreme rims require the use of the gorilla lug locks, if you dont use them, you might loose a wheel
Old Aug 10, 2009 | 08:56 AM
tuffysJKwrangler's Avatar
when i put my pro comp on i got the lugs from them too
Old Aug 10, 2009 | 09:35 AM
JIMBOX's Avatar
I've used ProComp Extreme alloys for years and always use their "Spline Lug Nuts", need special tool for use, like all are lock nuts
JIMBO
Old Aug 10, 2009 | 09:43 AM
R0ck's Avatar
When I ordered my wheels and tires from Discount Tire Direct, they came with new black lugs made by Gorilla.
Old Aug 10, 2009 | 11:04 AM
tbone1077's Avatar
with my procomp wheels, I had to use different lugs. The factory lugs would not fit in the sunken lug holes on the rim. Has a better look anyway.
Old Aug 10, 2009 | 11:45 AM
Bustabizz's Avatar
Former Member
You definitely don't want to use your stock lug nuts on them. The ones for the Aluminum rims from Procomp are 21183HT, and the steel wheels are 5451K.
