professional alignment after installing spacers?
Old Apr 12, 2012 | 09:11 AM
G DIESEL's Avatar
Default professional alignment after installing spacers?
I am about to install at least front 1" Terraflex leveling spacers. Maybe the 2" front and 1" rear. Instructions call for an alignment afterwards. Does this really affect the alignment significantly? What is everyone elses experience/advice?
Thanks!
Old Apr 12, 2012 | 09:14 AM
Huckleberryjeep's Avatar
i'm also curious about this. i want to get a leveling kit. i hate the look of the rake
4WheelingAstronomer's Avatar
I did a TF Leveling Kit (2inches in front, 1 inch in back) and everyone mentioned that I should get one. The way I figure it, you're moving your suspension around a whole lot....for $80 it's a smart idea. I don't however, have any evidence-based data to support this
Old Apr 12, 2012 | 09:21 AM
Joher's Avatar
You can do it yourself with some patience. Super easy
http://project-jk.com/jeep-jk-write-...-end-alignment
G DIESEL's Avatar
Where did you take it to get done? And did you install the sway bar links?
Great looking ride.
Old Apr 12, 2012 | 09:25 AM
Rich6700's Avatar
I did a leveling kit and did not get an alignment afterwards. It's not really needed since the only adjustments are centering the steering wheel and setting the toe, and your not messing with the toe adjustment and you can center the steering wheel yourself if needed. Teraflex is just covering there ass.
Old Apr 12, 2012 | 09:29 AM
yo_marc's Avatar
An alignment is not needed. Probably in the instructions for liabilities sake...
Old Apr 12, 2012 | 09:38 AM
yo_marc's Avatar
To fill that in a little more...
a 2" lift to the front will:
- Change your caster setting to a more upright setting - from 6.5* to 5* perhaps.
- Not affect your camber.
- Increase toe-in by a VERY small amount. Likely not noticeable by many..
Although some say it's not necessary, a 2" lift in the front will necessitate the need to re-center your steering.
The only settings that are adjustable on a stock suspended JK would be the toe-in and the draglink, (to center the wheel).
Old Apr 12, 2012 | 09:42 AM
G DIESEL's Avatar
I have 35" tires so some increased tow in would be beneficial to me.
Old Apr 12, 2012 | 09:52 AM
shoe1724's Avatar
As Rich said an alignment is not needed for a leveling kit. You might have to recenter the steering wheel to keep the ESP from freaking out.
