Programmer
Old Mar 25, 2009 | 05:58 PM
08JKER's Avatar
Default Programmer
Is there a programmer out there that allows you to shut the esp off completly???
Old Mar 25, 2009 | 06:11 PM
Goldorak's Avatar
look in the owner manual , you will find a procedure to deactivate the esp completely
it took me a couple of try to get it work it's pretty complicated for nothing
Old Mar 25, 2009 | 06:31 PM
AZJeeper's Avatar
Community Favorite
For sure not in the 2007 manual. I understand it will not work at all in 2007 models. Not in my version of the 2008 manual. I understand it works in later 2008 models - for sure doesn't work in mine. In the 2009 manual:
The following procedure will disable (or re-enable) ESP
functionality in the vehicle.
1. Shift the transfer case into the 4H range position.
2. Turn the steering wheel until it is centered and the
wheels are pointed straight ahead.
3. Cycle the ignition key OFF to ON.
4. Wait approximately five seconds for the system bulb
check.
5. Turn and hold the steering wheel one-half turn to the
right (clockwise).
6. Press and hold the ESP OFF button for seven seconds.
7. Turn the steering wheel back to center, and turn and
hold an additional one-half turn to the left (counterclockwise).
8. Press and hold the ESP OFF button for seven seconds.
9. Turn the steering wheel back to center.
10. Press and hold the ESP OFF button for seven seconds.
11. Cycle the ignition key to OFF.
After performing the ESP disable procedure correctly,
“ESP OFF” will be displayed in the odometer for approximately
12 seconds each time the ignition is moved to ON.
Repeating the ESP disable procedure will re-enable normal
ESP operation.
Get an Aeroforce Interceptor. Turns off ESP just fine.
Old Mar 25, 2009 | 06:40 PM
mkjeep's Avatar
Switch mod, tap the purple w/blue strpe wire, put a switch, turns off esp, bas, abs. Used to be a write up somewhere on here. On 07's anyway.
Old Mar 25, 2009 | 07:42 PM
gt4660's Avatar
check.
right (clockwise).
ESP operation.
I used this technique for my 08. But I had to have the jeep running for it to work.
Old Mar 25, 2009 | 07:52 PM
eDiveBuddy's Avatar
You can get the Aeroforce Interceptor. It's the only thing I know of that will actually turn all the ESP including ABS off.
