PS rocker knockers
Old May 16, 2016 | 05:02 AM
blamb0830's Avatar
Veteran: Marine Corp
Probably gonna take 50$ of it and pick up away bar quick disconnects. THANKS GUYS!!!
Old May 17, 2016 | 09:57 AM
jordy's Avatar
Loved
Community Favorite
Originally Posted by blamb0830
They are bolt on frame mounted going on a 2 door. I've read the instructions probably a hundred times. But it says you have to drill and tap the frame. I believe the rear go between the body mount and frame
I just did a set on a buddy's 4 door JK. It wasn't bad. The destructions could be better, but that seems to be the norm. On the 4 door, both sides aligned with an existing bolt so you had a reference point. Drilling the frame isn't a big deal other than laying on your back getting little bits of metal raining down. The 4 doors then have bolts that you have to drill holes into the horizontal cab supports. Once you get the first bolts started, you can clamp them into place, mark, drill and tap on the frame, and then drill the other supports. I'd have a hard time paying someone $250 to do it, but I've got a decent setup when it comes to my shop.
