PSC rock brawler rear bumper issue
So I just mounted up my new PSC brawler front and rear bumpers, and I'm having a issue with the license plate mount on the tire carrier. I'm using the farthest mounting hole on the tire mount, because the inner one is being covered by my rim. There is barely enough room to get in there and insert the long bolt that goes all the way through. That hole is also right up against my rim, but I am able to make it work. M problem is how wobbly it sits on there. Because of how it is, I can't seem to get in to get it overly tight to stop the wobble. It hangs low and sits at an angle since I can't use the inner hole lot mount on. Did anyone else have this problem? If so, how did you solve it?
