Psc steering install questions
Old Aug 4, 2011 | 05:24 PM
terminator 03's Avatar
Default Psc steering install questions
Hey Yall this is my first post but im havin a couple of issues. I recently installed the psc hydro assist steering for my jeep and then got it aligned but the traction control light and ebs lights are still on, i was wondering if anyone had any idea why this is? thanks
Old Aug 4, 2011 | 05:45 PM
PainKiller's Avatar
is your steering wheel centered ?
Old Aug 4, 2011 | 07:17 PM
Yeah its centered i just got it aligned today everything is good which is why i dont understand why its on, when i got it lifted both lights were on cause the front end was all outa wack once i got it aligned they went off
Old Aug 4, 2011 | 07:25 PM
The_Yeti's Avatar
Could possibly have a broken wire or bad wheel sensor.
Old Aug 4, 2011 | 07:35 PM
do you know if that would throw a certain code or not?
Old Aug 4, 2011 | 07:57 PM
KenB1010's Avatar
It takes about 30 miles of driving before the light will reset. If your drivability is good, just drive it for a couple days then if it doesn't reset start looking for problems
Old Aug 4, 2011 | 08:48 PM
alright sounds good thanks for the advice
Old Aug 5, 2011 | 12:51 AM
highoctane's Avatar
You don't also have an airbag light do you?
Old Aug 5, 2011 | 05:55 AM
The_Yeti's Avatar
off hand no i dont know. but when i had problems because my steering wheel was off the ESP/ABS would reset when i turned off the jeep. may just go around and check all of the wires. and could hitup an autozone or some parts store that will do a free code reading. if it comes up with a code it may tell you which one is having a problem.
A friend of mine had this exact problem and the wheel sensor was bad
Old Aug 5, 2011 | 06:33 AM
0llll0's Avatar
When you disconnected the steering shaft from the original steering box to install the new psc steering box, did you make sure you tied off the steering wheel so that it wouldn't turn a revolution or two by accident? It's possible for this to happen and if it did the steering wheel sensor thinks it's turned. Good luck. Hopefully you get it figured out.
