psi in tires
Old Jul 16, 2008 | 09:22 AM
bigjeepmm's Avatar
Default psi in tires
i have 295/70/17 toyos that say max 80lbs psi. how much should i inflate them to for highway driving?
thanks
Old Jul 16, 2008 | 09:31 AM
racer83l's Avatar
my .02.. start at 35-37 PSI. take childrens sidewalk chalk, make a line along the width of the tire, roll the JK a bitt.. check out the chalk if its wearing on the sides only, you have too little air, center, too much.. work with that and see what happens, If I were to guess youll end up in the high 20's..
Old Sep 18, 2009 | 06:59 AM
thanks
80 and the tire will last alot longer, will be a bit stiffer but you're in a jeep. the main reason for the high pressure is because the tire has a load rating and it can only handle this load at 80
Old Sep 18, 2009 | 07:01 AM
porters's Avatar
I want to see pics of your rig with those 295 Toyo tires. Please, please please please?
Old Sep 18, 2009 | 07:37 AM
nthinuf's Avatar
You're suggesting actually running at 80 psi? Are you freaking kidding?
Here is the blurb from the FAQ's stickied to the top of this section. Generally a decent place to start.
Q: On the road, what PSI should I be running in my tires?
A: For optimal comfort and even tire wear. you should not run the recommended PSI listed on the sidewalls of your tires. Typically this will be way too much. On average for a 33" tire, I would recommend that you run your tires at approximately 28-30 PSI. For a 35" tire, I would recommend running approximately 26-28 PSI. For a 37" tire, I would recommend approximately 24-26 PSI.
Q: On the trail, how much should I air my tires down to?
A: Typically, I recommend that people air the tires down to about 10~15 psi.
Try running them at various 'lower' pressures to see what feels best, and also do the chalk test to see what pressure gives the best footprint.
I generally run my 295/75/16's around 30-32psi. My tire shop puts them back up around 45 when I take it in for rotations, and the ride gets far too stiff and flighty.
Old Sep 18, 2009 | 08:20 AM
bareass's Avatar
i run 305/70/16, i felt them get low, and saw my mileage go way down. i checked them and i was at 30. i say low to mid 40's. i've heard (never done) that you can used a temp gun to check the heat on your tires after driving a bit.if its hotter on the outsides, put more air, center take some out, and only one side mean you out of alignment. sounds like a good idea to me!
Old Sep 18, 2009 | 09:56 AM
hvilla's Avatar
Just my 0.02> I have MickeyThompson's 33's and I run them at 28 on the street and 15 on the trail...
Higher than that you are just bumping around a lot. Yes, its a jeep, but you don't want to feel like you are inside a washing machine when you drive it...
Old Sep 18, 2009 | 10:15 AM
funtimes's Avatar
If you run them at 80psi, good luck.. that will be like having concrete wheels and it will shock your truck to pieces. I have 32 psi in my 35's and it's about right on.
Old Sep 18, 2009 | 11:02 AM
nthinuf's Avatar
One other thing to note is that those are load range 'E' tires. Very stiff sidewalls, designed for big heavy trucks hauling big heavy loads. If you don't plan on dropping a couple tons of gravel in the back of your JK, you'd be better off going significantly lower on the psi...
Old Sep 18, 2009 | 11:15 AM
AZJeeper's Avatar
Community Favorite
Don't know which Toyo this is, but the Open Country M/T is Load Range E (stiff sidewalls to begin with) and the Max Load = 3,970 lbs at 80 PSI
You didn't say what JK you have, but the curb weight of the 2-door is 3,849 lbs. One tire at 80 PSI is enough to support the whole Jeep, so here are my helpful suggestions:
  • Sell three and run one at 80 PSI.
  • Run 4 at 80 PSI and haul 12,000 lbs of cargo.
  • Lower the pressure to about 20 PSI and do the chalk test to find the best running pressure.
That's one mighty over-built tire for a JK!!
