Pulling left when braking
Old Jan 10, 2011 | 11:12 AM
notenuftoys's Avatar
Default Pulling left when braking
I just installed the TF 2.5" coil kit, and now it pulls left under hard braking. Would an adjustable trackbar fix this? Does it pull because the axle is slightly off-center?
If so, I'll have enough money next month to buy one. If not, what should I check for?
Old Jan 10, 2011 | 01:15 PM
Bosox5's Avatar
Veteran: Coast Guard
I had this problem before I added a front adjustable trackbar and front lower control arms on my TF 2.5 coil kit, you need to increase your caster with the addition of the lift and bigger tires. Hope this helps.
