Pulsing Vibration After New Gears Installed
Old Jun 24, 2013 | 07:37 PM
  #21
adamisadam's Avatar
Question: should the front and rear drive shafts rotate or have the same amount of rotational play? What I mean is, when I'm under the Jeep and I grab the drive shafts with my hand, I can rotate the front shaft about 1/2" of a turn, and the rear almost no rotation at all. Is this normal?
FYI: I just re-geared and rebuilt both diffs. I could swear I'm hearing a bearing noise under 40 mph. It's constant sounding with no change in sound if I am on/off the gas. It's speed related. Almost sounds like worn brake pads (while coasting, not under braking).
Mind you, IT'S VERY SLIGHT. Most wouldn't hear it. Wind noise drowns it out. It could all be in my head.
Old Jun 24, 2013 | 08:26 PM
  #22
JKJeepJunkie's Avatar
Sounds like you are just like me you know your jeep beat and if anything is different your the first to pick it out but if you had a shop gear it I would take it to them and let them check it out and ride in the passenger seat maybe there you can better identify the problem
*O||||||O*
Old Jun 24, 2013 | 08:44 PM
  #23
adamisadam's Avatar
Yup, I have an appointment next week. But what about the difference in free play rotation between front and rear drive shafts? Is that normal?
AdamIsAdam
Old Jun 24, 2013 | 08:48 PM
  #24
AdamIsAdam
Hang on ill check mine right quick
*O||||||O*
Old Jun 24, 2013 | 08:54 PM
  #25
AdamIsAdam
I've got about 1/4 turn on the front and hardly any on the back driveshaft
*O||||||O*
Old Jun 24, 2013 | 10:49 PM
  #26
GunDude's Avatar
I did not install gears but, I did install new Coast F/R drive shafts this past Saturday. I just checked mine, and I have a very, very little play in the front shaft, and around the output shaft of the tc.
Old Jun 25, 2013 | 03:17 PM
  #27
adamisadam's Avatar
*O||||||O*
Cool. Thanks! I wonder if it should be neutral, if that will make a difference. But anyway I think this is normal
AdamIsAdam
Old Jun 25, 2013 | 05:40 PM
  #28
adamisadam's Avatar
duh! I put it into Neutral and sure enough, the slack is equal front and rear.
Old Jun 25, 2013 | 11:27 PM
  #29
Ok so eliminated that possibility are you still getting vibes from it when driving
*O||||||O*
Old Jun 26, 2013 | 01:51 PM
  #30
adamisadam's Avatar
Mine never vibrated, just makes a slight constant sound that only varies with speed, not throttle input. But it's very slight.
AdamIsAdam
