PureJeep rear decision
Old Mar 26, 2008 | 07:05 AM
Mountjk's Avatar
Default PureJeep rear decision
Im getting ready to order a purejeep rear bumper my only question is: If I dont plan on going bigger than 35 inches on my tires is there any reason to pay 300 more for the tire carrier? Thanks for your help
Old Mar 26, 2008 | 07:36 AM
saltman's Avatar
I would get it if you plan on bigger than 33" tires. 35s would probably weaken the tailgate/hinges over time. I know it would on a TJ and a JK has to be worse since the gate is wider and puts more force on the hinges. You could also get a different style carrier at a later time like the ones that OR-Fab makes and keep your PJ bumper. that is another option.
Old Mar 26, 2008 | 07:37 AM
yellowrubi's Avatar
i wouldnt pay extra, from what i hear the stock carrier can hold up to 35s just fine
Old Mar 26, 2008 | 07:54 AM
Mountjk's Avatar
Ive had 35's for almost a year but only recently put a spare on. I went with 16 inch wheels and would think that would save a little weight considering i had 18s before.
Old Mar 26, 2008 | 08:59 AM
Ctimrun's Avatar
Over time that 35 will wear out your stock gate hardware, not to mention rattle like crazy if you drive at all on washboard roads. $300 is cheap compared to the price you will pay to get it fixed. I would buy the tire carrier as well!
Old Mar 26, 2008 | 09:18 AM
Mountjk's Avatar
Is a 35 inch tire mounted on a 16 inch rim that much heavier than the 18inch sahara wheels and tires?
Old Mar 26, 2008 | 01:09 PM
yellowrubi's Avatar
I take back what I said after reading this thread I think I will have to get me a tire carrier This site is very informative...
Old Mar 26, 2008 | 01:21 PM
Ctimrun's Avatar
Yes it is. The lightest 35 and wheel will be a lot heavier. This is not the lightest, but for example the Toyo 35" tire alone weighs 83 pounds. Add in a rim and you are well over 100 pounds....
Old Mar 26, 2008 | 01:26 PM
BLKRUBI's Avatar
My 35" Mud Grappler and PSC 18" wheel weighs somewhere around 125-130lbs and considering my stock Rubicon wheel/tire only weighed like 85lbs, that's a lot of extra weight for something that wasn't designed for it.
Old Mar 26, 2008 | 03:38 PM
mmcan's Avatar
I just got the Rock Hard rear bumper with tire carrier and am very impressed with it.
It carries a 37" tire easily.
Check it out,...
http://www.rockhard4x4parts.com/jk-rear.html
