Quadratec - Need help with BD Shocks !!
Old Nov 7, 2008 | 03:18 PM
BigBadMike's Avatar
Default Quadratec - Need help with BD Shocks !!
I need help from anyone with experience or Quadratec sponsor. BOUGHT FROM QUADRATEC.
I bought the Black Diamond AT Shocks for 2" lift. There are no instructions in any of the boxes. The rear shocks are a no brainer as the top mounting posts are installed and the bottom only requires the bushing/metal sleeve to be installed. The front shocks have me stumped. I know the bushing/metal sleeve goes in the bottom, but I have about a dozen pieces for the top "Stem" portion, and have no idea which parts to use, and what order they go on.
I have:
(2) large concave washers (like a soup bowl)
(2) smaller washers with a center indentation
(2) poly bushings
(3) nuts
I tried talking with a gentleman at Black Diamond/Superlift who apparently knew less then I did, so no help there really.
Also, dont know how I'm supposed to tighten the nut on top as the whole piston rotates with nowhere to hold it to keep it still.
** PLEASE HELP !! **
Really not happy with a lack of instructions and a lack of product knowledge from Black Diamond Tech Support.
Old Nov 7, 2008 | 03:38 PM
Fermin's Avatar
Would the instructions for the 3" help?
http://www.quadratec.com/Assets/Installation/77588.pdf
Old Nov 7, 2008 | 03:51 PM
motorhead0320's Avatar
i will try and explain this best i can without having pictures.
with you shock standing straight up you should install the parts in this order.
1 metal washer with concave pointing up.
next a poly bushing with the side with a raised portion pointed up.
then instal shock
next a ploy bushing on top with raised portion aiming down.
then another metal washer with the caoncave pinted downward.
next a nut
then a another nut(as a jam nut if provided)
hope this helps. hopefully you can understand what i am describing since you have the parts in front of you.
Old Nov 7, 2008 | 03:58 PM
just went and took these pics, hopefully they explain what i was trying to say.
Old Nov 7, 2008 | 04:10 PM
BigBadMike's Avatar
I will go and assemble as you have. Since I have two sets of washers. I'll put the ones on that are roughly the size of the poly, and see how it looks compared to yours.
I really, truely appreciate your help and for taking the time to take and post the pics. As always, a jeeper goes above and beyond...
Thanks,
Mike
Old Nov 7, 2008 | 04:42 PM
BigBadMike's Avatar
Default Like this ?
I think this is the set up you have shown me. Is it correct? Thanks a bunch buddy.
Old Nov 8, 2008 | 02:14 AM
just like that.
Old Nov 8, 2008 | 06:21 AM
BigBadMike's Avatar
Old Nov 9, 2008 | 04:01 AM
HappyCurmudgeon's Avatar
Eternal ***erator
Watch the torque on the top bolts, dont tighten them down enough to make those bushings flatten out like a roadkill cat, they are supposed to maintain their shape.
Old Nov 9, 2008 | 08:03 PM
kurtfriedrich's Avatar
and as for; "Also, dont know how I'm supposed to tighten the nut on top as the whole piston rotates with nowhere to hold it to keep it still."
I suspect the very top of the shock has 4 flat sides so you can get a wrench on it to keep it from spinning.
Kurt
