Ques re Arb "cycling"
Have new Arb lockers front (d30) and rear with Arb HO compressor under hood. Everything normal if using rear locker only. However, with front locker engaged SOMETIMES the compressor needs to cycle every 10 secs or so. Sometimes no cycling. only cycles if also in gear and moving. If sitting in neutral, nothing.
Puzzling to me. Any guesses?
More than likely you have a leak in the air line, possibly at the differential housing. Then trace the air line back to the solenoid and check for tightness and leaks there (could be a bad solenoid)
