Question for 3" JK 2Dr and 2,5" Budget Boost
Old Nov 23, 2007 | 09:12 AM
lolli's Avatar
Default Question for 3" JK 2Dr and 2,5" Budget Boost
I want say if i istall on my Jk Rubicon a lift Kit 3" Teraflex I must install also DriveShaft front and rear?
I want say if with the 2,5" Teraflex Budget Boost is possible mount the 35x12.50 r17?
Thanks!
Scuse for my English
I'm Italian
Old Nov 23, 2007 | 10:30 AM
Brodmans4's Avatar
I have not heard of people needing new drive shafts for a 3" lift on a 2 door JK.
A 2.5" budget boost will be perfect for 35x12.50x r17 tires, and will maintain all your factory components
Old Nov 23, 2007 | 10:34 AM
AK4Dave's Avatar
No.....you do not have to change drivelines.
Old Nov 23, 2007 | 12:52 PM
Piginajeep's Avatar
You guys need to read a little more.
Theres alot of us needing new rear driveshafts for the 2 door and a 3" lift.
The front should be OK for awhile. The rears steep it'll cause your driveline to fail after awhile. You might last 12 months, it might only last 3 months.
My rear failed about 3 or 4 months after the install of my 3" lift..
Old Nov 23, 2007 | 03:24 PM
Tebo's Avatar
So what was required to fix the problem? If its the angle can you buy a bracket to drop the angle to go along with the BB?
Old Nov 23, 2007 | 03:32 PM
Piginajeep's Avatar
You shouldnt have much issues with a BB lift. But a 3" you will.
You have to buy a U-joint style driveshaft.
Old Nov 23, 2007 | 03:59 PM
Keene oh8JK's Avatar
When I called about having a 3" suspension lift installed the guy told me I would need a slip yoke eliminator and a new drive shaft .... So BB here I come!
Old Nov 23, 2007 | 04:11 PM
Piginajeep's Avatar
well thats because he doesnt know what he is talking about. I would find a mechanic that has more knowledge about the JK's.
You would need that If you were lifting a TJ (1997-2006)
Jk's dont require a SYE.
its just the driveshaft and possibly a yoke depending on what you want.
Old Nov 23, 2007 | 05:22 PM
Phishjeep's Avatar
I can't tell from your pictures, but are your driveshafts the heavy duty 1350. or 1310? How much lift will the 1350 be usable on? Can I put on 1350 with a 2-3 inch lift and then upgrade to 4 inch later? What about 6 inch?
Old Nov 23, 2007 | 05:33 PM
Piginajeep's Avatar
I'm running the 1350's.
I've read where they say the 1350's will bind up before the 1310's. But really dont thinks its that big of an issue. However I could be wrong. Its happened once before...
I dont know what size lift the shafts are good too. Just from looking at them at full drop I would guess, a 4" lift would not be an issue. I keep meaning call Fulltraction and ask.
I plan on going to the 4" long arm, as soon as money will allow me. So I guess I should find that out!
