Question on 35's
Old May 21, 2011 | 12:37 PM
Jeremy072288's Avatar
Default Question on 35's
What's the psi supposed to be at for 35 Inch tire?
Old May 21, 2011 | 12:47 PM
TCORUM's Avatar
https://www.jk-forum.com/forums/show...274#post211274
Q: On the road, what PSI should I be running in my tires?
A: For optimal comfort and even tire wear. you should not run the recommended PSI listed on the sidewalls of your tires. Typically this will be way too much. On average for a 33" tire, I would recommend that you run your tires at approximately 28-30 PSI. For a 35" tire, I would recommend running approximately 26-28 PSI. For a 37" tire, I would recommend approximately 24-26 PSI.
Scott08X's Avatar
Most people run 30psi +/- a few pounds
Old May 21, 2011 | 01:33 PM
genesbro's Avatar
I run about 25-26 psi in mine, in fact when it is real cold it will cause my tire pressure warning to come on and I have that set at 24 psi.
Old May 21, 2011 | 01:37 PM
IcyFridge's Avatar
I run my 33s (Load rated D) tires at 33psi. When its colder out 30psi trips my TPMS. When I get my superchips, I will be running 30 at all times. With 35s, I would go 28 to 30 psi depending on the tire stiffness.
Do a chalk test for accurate results.
Old May 21, 2011 | 02:06 PM
MOKOS's Avatar
run mine at 28psi and it's wearing very evenly after about 30,000 miles.
Old May 21, 2011 | 02:28 PM
jvandy50's Avatar
Which 35 do you have? I have the toyos and they ride much better around 26-28 imo
Old May 21, 2011 | 02:36 PM
Yea I have Toyo m/t. I'm gonna have to drop my psi then lol
Old May 21, 2011 | 02:44 PM
peanut's Avatar
28 psi works for me
Old May 21, 2011 | 06:23 PM
jvandy50's Avatar
I think you will like the ride a whole lot better
