Question? 5.13 Gears And 37's
Old May 18, 2008 | 04:10 PM
SLICKWILL's Avatar
Default Question? 5.13 Gears And 37's
What Is The Average Mpg
2 Door 5.13 Gears City And Highway
Looking For People Running This Set Up
Thanks Will
Old May 18, 2008 | 04:23 PM
tkob1060's Avatar
From: Hangin in the sunshine state....staging forum..
Will you keepin her?
Old May 18, 2008 | 04:28 PM
SLICKWILL's Avatar
idk yet..... but my minds rest less hahaha if i do ill be regearing her dana 44 front and she will be a daily driver again so no more wheeling.... not sure yet still better off to sell her
Old May 18, 2008 | 04:37 PM
tkob1060's Avatar
if you build it with a 44 you will be good to go wheelin and still dd
Old May 18, 2008 | 04:45 PM
Mowabb's Avatar
I have a four door with auto trans. I get 12-13 mpg to and from work. The best I have done is 16 on the highway.
Old May 19, 2008 | 09:14 AM
SLICKWILL's Avatar
not sure if its a wise thing to do 5.13 and daily driving
Old May 19, 2008 | 09:31 AM
TeraFlex's Avatar
Sponsoring Manufacturer
Gettin about 15-16 with my 5:13's and 37" Coopers. Got a auto trans with the HyperTech Speedo Calib. unit. I drive about 50 miles a day.
Old May 19, 2008 | 09:58 AM
TEEJ's Avatar
Talking
Originally Posted by putnam dan
why ever not, I'm doing around 2500 rpm which can do no harm at all.
OK, There's sure no harm in running 2,500 rpm...hell the engine can handle more than that any day....but I think the MPG part was the wisdom questioned.
I'll do a rough calculation that with 5.13's turning 35's at 2,500 rpm, that you are averaging roughly ~ 64.5 - 65 mph...a reasonable cruise speed for the NY - Princeton Commute.
You are carrying a lifted armored rig on those 35's...so if a stock JK could get about 18 mpg under those conditions...then you should be closer to 15 mpg in steady traffic, and somewhat less per gallon if its stop/go...but then you would not be at 2,500 rpm cruising along either.
If you were to drop to about 45 mph, your mpg would probably soar to more like 22 mpg, as the wind resistance would be cut significantly.
Of course, at 100 miles each way, that would add ~ 40 minutes each way to your commute.
At ~ 15 mpg, 200 miles for the day = ~ 13.3 gal, at $4/gal = $53.33 per day in gas.
At 22 mpg, that's 9.1 gallons per day = ~ $ 36.36 per day in gas....saving $16.97 per day in gas.
So you pay the difference to get 40 minutes more sleep, and to get home 40 minutes earlier.
Seems reasonable.
Old May 19, 2008 | 01:47 PM
greenmachine07's Avatar
idk if anyone could rele explain it better
Old May 19, 2008 | 01:48 PM
SLICKWILL's Avatar
Well If I Can Swing It Im Going This Route Sounds That 5.13 Will Help My Mpg So Makes It More Of A Daily Driver Which Is What I Need
