Question about control arms
Old Mar 25, 2009 | 09:24 AM
ISLANDJEEPJK's Avatar
Originally Posted by Robar
The main thing is tire wear. You want to have even tire wear across the entire tread pattern Having to much air will wear the inside of the tread prematurely and to little will wear the outside prematurely. Also to much air will cause a rough ride and sometimes make the steering feel flighty.
So what is the deal with the tire saying you can run 65 psi?
Old Mar 25, 2009 | 09:25 AM
Robar's Avatar
That is a max psi. Just because you can put 65 psi in the tire doesn't mean you should.
Old Mar 25, 2009 | 09:26 AM
wayoflife's Avatar
JK-Forum Founder
what he said
Old Mar 25, 2009 | 09:31 AM
Hey Thanks. Can I get you opinino on lights? If I am looking for lights mainly to help in snow and rain, should I go with KC Slimlites as fog or driving?
Old Mar 25, 2009 | 09:32 AM
Robar's Avatar
I personally went with dual beam PIAA lights. They have a yellow beam for fog and weather and a white driving light for clear conditions and all in the same light housing.
Old Mar 25, 2009 | 09:35 AM
They are doing to be mounted on a MBRP gril guard upside down. Can the stone guards be flipped and did you go with the 520 or 525?
Old Mar 25, 2009 | 09:37 AM
Robar's Avatar
I have the 525s, but they are not supposed to be mounted upside down. The yellow would face high and the white would face low.
Old Mar 25, 2009 | 09:39 AM
Yeah, that wouldn't work, so should I go with fog or driving? I know the Piaa 520 or the yellow ion lights but I don't know if the covers can be flipped. I have had the Piaa on my wrangler but they were right side up.
Old Mar 25, 2009 | 09:43 AM
Robar's Avatar
If you get a lot of fog in your area that's what I would go with if not, I would consider the driving lights.
Old Mar 25, 2009 | 09:47 AM
Thanks for all you help. I think I will go with the driving lights.
