Question about new wheels
Alright if i were to get new wheels for my 08 Rubi would i have to get the exact same size as the stock 17x7.5's or could i put on different size wheels. I really want to get some soft 8s and I'm not sure if i will be able to find 17x7.5s with 5on5 bolts. If so how much can it be off by?
you dont have to get same size,,,just make sure offset is right so you dont rub...i think its supposed to be 4.5. ask your local tire shop............. personally i would run same size, as in diameter. can go as wide as your rig will allow.
Im running the pro comp 8179 15x10!! they look awesome. The clear the brake caliper by less than an inch but it will never move so it works great. just fyi. if you decide to ever go bigger tires for 15 inch rims cost less and give you more flotationaka that huge rubber look. Id say 1 17x9 with 3.65 to 4.25 backspacing would giv ea nice wide look. good luck.
