Question about TeraFlex Leveling Kit vs. others
OK, I'm looking at adding a small (ok cheap) lift to my stock Rubicon. I am drawn to the TeraFlex leveling kit based on forum discussions but I've got a couple of questions...
1) Similar leveling kits from other manufacturers only include the spacers. TeraFlex adds front sway bar links. What purpose do these serve? http://www.teraflex.biz/products/jk-...eling-kit.html
2) How long should this install take from a shop? I want to make sure I'm quoted a fair price.
The install is really pretty easy in your own driveway. It would be a shame to pay a shop for it. I could see a shop easily charging 4 hours for a spacer install on 4 corners.
The install is really pretty easy in your own driveway. It would be a shame to pay a shop for it. I could see a shop easily charging 4 hours for a spacer install on 4 corners.[/QUOTE]
I agree completely. I put a TF leveling kit on last week. Looks great for the price. I borrowed a set of metric wrenches and sockets, and two jack stands. I used the stock jack from my jk.Took me three hours but it was pretty simple. Would have been a little easier with someone else there to push down on the axle for me, but I didn't want to wait....
its a great option, and now in the future I can turn that into a 3" lift or more by adding a relatively cheap coil/suspension lift and leaving the spacers in. I'm eyeing a 2 inch lift from BDS....I say go for it. You wont regret it. After you install it you'll be really glad you didn't pay 300 bucks or more for someone else to do it. Also you'll learn alot about your rig. i'm confident after that install that when the time comes I'll be able to install my own suspension coil lift with no problems.
This is not a situation where you need to pay for an install. Dive in.
I was quoted $250 by the local shop to install the leveling kit. I ended up installing the kit myself (which is a great learning experience). If you don't have a floor jack, jack stands or the tools needed to do the job you should weigh the cost of acquiring these against paying someone else to do it for you. I guess it just depends on whether you believe you'll ever use those tools again. Good luck and let us know how it turns out!
The shop down the street from my house told me that labor would run about $400.00 on this install (TF level kit). I don't own any tools and i don't know anything about mechanics, but i'm doing it myself
ht tp://www.sears.com/shc/s/p_10153_12605_00935283000P?vName=Tools&cName=Tool+ Sets&sName=View+All
a 21mm wrench, 1/2" drive torque wrench, a 1/2" Breaker Bar, and some jack stands and you should be good to go.
Get yourself this tool set, it is a great starter set:
Thanks for the advice
Have fun.
