question for all you m/ters
Old Mar 8, 2013 | 08:54 AM
jk_sea's Avatar
Clearly I missed the point of this one and re-reading my post, it sounds preachy. You're going to feel pull regardless. I agree with 4W though, a skinnier tire with better channeling will mitigate the effect to some degree.
Old Mar 8, 2013 | 08:55 AM
expletivedeleted's Avatar
Originally Posted by 4W-Jive
Lug depth would be the same as tread depth, and yes the pulling sensation you're describing will increase with tire wear. And also 2.5" in tire width is huge! Remember to multiply that by 4 too!
why multiply by 4 =-o ok tread depth ty
Old Mar 8, 2013 | 09:02 AM
4W-Jive's Avatar
Take 4 tires at 10" wide, you're displacing effectively 40" of water (width of path). Now take 4 tires 12.5" wide and you're displacing a path of 50". That's a 20% change with no change in weight to compensate.
Old Mar 8, 2013 | 09:06 AM
also seems like the space in between the tread would be another factor. and most other m/ts have closer lugs than the km2 it seems to me. but ofc thats not another measurement either haha. but a tread depth of 20/32 is talking about a fraction of an inch i assume? or is it something entirely different
Old Mar 8, 2013 | 09:07 AM
Maertz's Avatar
The weight should be a little higher as a taller wider tire will probably weigh more
Old Mar 8, 2013 | 09:09 AM
oh gotcha. true dat.
i guess its a far reach but i wont really know for sure unless i ride along with someone with different tires or find someone who has ridden a km2 and another m/t to really know for sure. might just have to find me an aggressiveish lookin a/t haha. im not too mad at nittos a/t
Old Mar 8, 2013 | 09:15 AM
4W-Jive's Avatar
The weight of the tire will not effect the pulling sensation the OP is talking about.
Old Mar 8, 2013 | 09:18 AM
4W-Jive's Avatar
Yes a fraction of an inch. And I know what you mean, I refer to it as positive surface area of the lugs vs. negative area (where there is no lug). The more negative area will help reduce the pulling sensation but will also reduce the life of the tire and many handling characteristics.
Old Mar 8, 2013 | 09:20 AM
4W-Jive's Avatar
Just look for a narrow tire in the height you want.
Old Mar 8, 2013 | 12:12 PM
i think id rather have fat tires than ones with crazy tread.
