Question on Mounting and Balancing
I am trying to order some rims and tires on the internet. It is giving me this message.
The tires cannot be mounted and balanced on the wheels in your cart because you will need sensors for the vehicle's tire pressure monitoring system. Currently, we do not carry the sensors you need.
You can purchase the tires and wheels separately now, but a trained technician will need to install your original sensors or sensors you purchase elsewhere when your tires and wheels are installed.
Then it gives me the option to mount and balance the tires without the sensors, and proceed to checkout.
The rims are 17 inch with 4.5 inch back spacing and the tires are 35 12.50x17.
Should I be concerned. Thanks
you are fine without the tpms and if you have an 07, you won't even have any tpms to deal with. without the tpms, the idiot light on your dash will show you have low tire pressure but, if you get an aev procal, you can turn this off.
