Question newbie
Old May 11, 2014 | 01:59 PM
bonkers789's Avatar
Default Question newbie
Have a 2013 jku want to do the bds 4.5 lift and 35 12.5 20 do you think I will run into any troubles. Or suggest anything different Once jeep comes out of the shop I'll put some pics up.
Old May 11, 2014 | 02:43 PM
afpilot82's Avatar
JK-Forum Ambassador
No troubles if your pockets are deep enough. That's a lot of lift for 35s. Need to think about a new front driveshaft and adjustable control arms at that height, among several other things. Why do you want 4.5"?
Old May 11, 2014 | 02:59 PM
bonkers789's Avatar
Want to do the bds lift which only has 4.5 or the rough country 4" I don't want to a body lift at all.
Far as the size of lift figured that would be the size I would need to run 35" 20
Old May 11, 2014 | 03:06 PM
Mark Doiron's Avatar
Recommend you read Dirtman's post, "My Thoughts on Lifts", in the modified JK stickies. Great info.
Old May 11, 2014 | 03:24 PM
Jeepstin12's Avatar
You do need to read dirtmans thread. As for the lift over 3", that's where a lot of components need to come into play. I have a 3" with 35's, wheel in Colorado and have plenty of lift for the tires and articulation clearance. Best of luck!
Old May 11, 2014 | 03:39 PM
BombJock's Avatar
BDS also has 2" and 3" I believe.
